CVE ID: CVE-2026-43633
Published: May 19, 2026, 2:16 p.m.
Description: HestiaCP versions 1.9.0 through 1.9.4 contain a deserialization vulnerability in the web terminal component caused by a session format mismatch between PHP and Node.js that allows unauthenticated remote attackers to achieve root-level code execution. Attackers can inject crafted data into HTTP headers that are processed by the PHP session handler but incorrectly deserialized by the Node.js web terminal component as trusted session values, resulting in arbitrary command execution on systems with the web terminal feature enabled.
Severity: 10.0 | CRITICAL
Visit the link for more details, such as CVSS details, affected products, timeline, and more...
https://cvefeed.io/vuln/detail/CVE-2026-43633
CVE-2026-43633 - HestiaCP 1.9.0-1.9.4 Deserialization RCE via Web Terminal
