CVE-2026-116568 - FreeSWITCH: Out-of-bounds read in mod_rtmp H.264 video message parsing
CVE ID :CVE-2026-116568
Description :FreeSWITCH is a Software Defined Telecom Stack enabling the digital transformation from proprietary telecom switches to a software implementation that runs on any commodity hardware. Prior to 1.11.2, rtmp_rtmp2rtpH264() trusted the length prefix of each inbound H.264 NAL unit without checking it against the bytes remaining in the RTMP message. An oversized declared unit underflowed the unsigned remaining-byte counter and advanced the parser beyond its receive buffer, where the next length-prefix read could crash the process. The flaw affects deployments that build and load mod_rtmp and accept video call sessions, commonly on TCP port 1935; placing the call requires a directory login where auth-calls is true, while no credentials are required where auth-calls is absent or false. A remote client can terminate FreeSWITCH and every active call, but the defect supplies no write primitive and memory disclosure has not been demonstrated. This issue is fixed in version 1.11.2.
https://cvefeed.io/vuln/detail/CVE-2026-116568
