CVE ID :CVE-2026-77879
Published : Nov. 2, 2026
Description :Control Web Panel (CWP) before webpanel_version 1.16 contains a SQL injection vulnerability in the loopback API authentication gate access_token(), which connects to MySQL as root and interpolates attacker-controlled values directly into its query. Attackers can inject SQL through the authorization_code and client_id parameters to read arbitrary database contents and forge the authentication result, bypassing the API's authentication check.
Severity: 8.5 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-77879
CVE-2026-77879 - Control Web Panel (CWP) < 1.16 SQL Injection via access_token() API
