CVE ID :CVE-2026-86047
Published : 2026-10-16
Description :MariaDB server is a community developed fork of MySQL server. From 10.6.1 until 10.6.28, 10.11.19, 11.4.13, 11.8.9, 12.3.3, and 13.0.2, SHOW CREATE SERVER, SHOW CREATE USER, and mariadb-dump are affected because each does not consistently quote identifiers and values when serializing SQL. A low-privileged attacker can trigger the issue when an attacker-created object with crafted identifiers or values is included in SHOW output or a dump, then create an object with crafted identifiers or values so generated SQL contains injected statements and execute attacker-injected SQL when the poisoned output is applied. This issue is fixed in versions 10.6.28, 10.11.19, 11.4.13, 11.8.9, 12.3.3, and 13.0.2.
Severity: 7.7 | HIGH
More Info:
https://cvefeed.io/vuln/detail/CVE-2026-86047
CVE-2026-86047 - MariaDB: Insufficient quoting in mariadb-dump and SHOW commands
