CVE-2026-94197 - NGINX Ingress Controller vulnerability
CVE ID :CVE-2026-94197
Published : Oct. 14, 2026
Description :An authentication and authorization bypass vulnerability exists in F5 NGINX Kubernetes Ingress Controller (NIC) when configured with the `ExternalAuth` policy or Ingress external authentication. Client-supplied X-Forwarded-Prefix, X-Forwarded-URI, X-Original-URI, and X-Forwarded-Method routing and method headers are forwarded unsanitized into the internal authentication subrequest (handled by the NGINX auth_request directive). As a result, an unauthenticated, remote attacker may spoof request attributes evaluated by the external authentication provider. Impact: This vulnerability may allow remote attackers unauthenticated access to protected paths. There is no control plane exposure; this is a data plane issue only. Note: Software versions which have reached End of Technical Support (EoTS) are not evaluated.
Severity: 8.7 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-94197
