CVE-2026-106067 - Gimp: gimp: heap buffer overflow in hot color filter on oversized image
CVE ID :CVE-2026-106067
Published : Oct. 7, 2026
Description :A heap-based buffer overflow was found in GIMP’s Hot color filter plug-in. For very large images, a pixel buffer is allocated using overflowing 32-bit width * height (and related) arithmetic while the filter’s pixel access path uses the true image size, after integer overflow in the allocation size
Severity: 6.3 | MEDIUM
https://cvefeed.io/vuln/detail/CVE-2026-106067
