CVE-2026-106066 - Gimp: gimp: heap buffer overflow in raw data export on oversized image dimensions
CVE ID :CVE-2026-106066
Published : Oct. 7, 2026
Description :A heap-based buffer overflow was found in GIMP’s raw data export plug-in. When exporting very large images, g_malloc() sizing based on overflowing width * height * bytes-per-pixel can allocate far less memory than GEGL reads or writes during export, following integer overflow
Severity: 6.3 | MEDIUM
https://cvefeed.io/vuln/detail/CVE-2026-106066
