CVE-2026-101009 - aaPanel BaoTa Unzip panelTask.py panelTask.bt_task._unzip os command injection
CVE ID :CVE-2026-101009
Published : Sept. 28, 2026
Description :A vulnerability was determined in aaPanel BaoTa up to 11.8.0. The affected element is the function panelTask.bt_task._unzip of the file /www/server/panel/class/panelTask.py of the component Unzip Handler. Executing a manipulation of the argument Password can lead to os command injection. The attack may be performed from remote. The exploit has been publicly disclosed and may be utilized. The vendor was contacted early about this disclosure but did not respond in any way.
Severity: 8.5 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-101009
