CVE ID :CVE-2026-101008
Published : Sept. 28, 2026
Description :A vulnerability was found in aaPanel BaoTa up to 11.8.0. Impacted is the function merge_split_file of the file /www/server/panel/class/files.py of the component File Merge Handler. Performing a manipulation of the argument split_file_path results in command injection. The attack is possible to be carried out remotely. The exploit has been made public and could be used. The vendor was contacted early about this disclosure but did not respond in any way.
Severity: 9.1 | CRITICAL
https://cvefeed.io/vuln/detail/CVE-2026-101008
CVE-2026-101008 - aaPanel BaoTa File Merge files.py merge_split_file command injection
