CVE-2026-101007 - aaPanel BaoTa Database Backup database.py InputSql os command injection
CVE ID :CVE-2026-101007
Published : Sept. 28, 2026
Description :A vulnerability has been found in aaPanel BaoTa up to 11.8.0. This issue affects the function InputSql of the file class/database.py of the component Database Backup Handler. Such manipulation of the argument Password leads to os command injection. The attack can be executed remotely. The exploit has been disclosed to the public and may be used. The vendor was contacted early about this disclosure but did not respond in any way.
Severity: 8.5 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-101007
