CVE-2026-81996 - Acrobat Reader | Incorrect Authorization (CWE-863)
CVE ID :CVE-2026-81996
Published : Sept. 8, 2026
Description :Acrobat Reader is affected by an Incorrect Authorization vulnerability that could result in privilege escalation. A low-privileged attacker could exploit this vulnerability to gain elevated access. Exploitation of this issue does not require user interaction. Scope is changed.
https://cvefeed.io/vuln/detail/CVE-2026-81996
