CVE ID :CVE-2026-57159
Published : Sept. 4, 2026
Description :PJSIP is a free and open source multimedia communication library written in C. Prior to commit 673b978, a remote out-of-bounds read and write can occur in the SDP negotiator when the remote payload-type map maintenance feature is enabled. assign_pt_and_update_map() in pjmedia/src/pjmedia/sdp_neg.c uses payload-type numbers taken from a remote SDP offer or answer to index fixed-size internal tables without sufficient bounds validation, so a crafted remote SDP can cause memory access outside those tables. The practical impact is memory corruption and denial of service; code execution is not demonstrated. This path is only reached when PJMEDIA_SDP_NEG_MAINTAIN_REMOTE_PT_MAP is enabled. The default is disabled, so default builds are not affected; the feature is an interoperability option that integrating products may enable. This issue has been patched via commit 673b978.
Severity: 8.4 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-57159
CVE-2026-57159 - PJSIP: SDP parser out-of-bounds write in remote payload-type map maintenance
