CVE-2026-81715 - openssl_encrypt before 1.4.9 Credential Exposure via Debug Output
CVE ID :CVE-2026-81715
Published : Aug. 27, 2026, 5:21 p.m. | 48 minutes ago
Description :openssl_encrypt (pip package openssl-encrypt) versions <= 1.4.8 do not redact the keyserver bearer token passed as the positional argument to 'keyserver set-token' in the --debug argv dump, because sanitize_argv_for_debug fails to sanitize it. As a result the token is printed in cleartext to stderr under --debug (even without --unsafe-show-secrets), persisting the credential in logs and terminal history. Fixed in 1.4.9.
Severity: 8.7 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-81715
