What you need to know
The vulnerabilities affect different parts of the request path:
- CVE-2026-60137: SQL injection. A vulnerability in WordPress version 6.8 and later allows crafted input to alter a database query. Rating High.
- CVE-2026-63030: Unauthenticated remote code execution. A vulnerability in WordPress version 6.9 and later allows an unauthenticated attacker to execute code through the batch endpoint of the REST API when a persistent object cache is not in use. This vulnerability is related to the SQL injection described above. No login or user interaction is required to exploit this vulnerability. Rating Critical.
Defense in depth while you patch
The SQL injection rule detects crafted parameter values before they reach WordPress. The unauthenticated RCE rule targets requests attempting to reach the remote code execution path. Together, they detect the attack at two different points.
These rules reduce risk while organizations update affected systems; they do not fix the underlying vulnerable code. Updating WordPress remains the most effective way to address the vulnerabilities.
If an immediate update is not possible, verify that both Cloudflare rules are active with the recommended action and review logs for suspicious requests to the affected REST API endpoint.
Published Date: Jul 17, 2026
Vulnerabilities has been mentioned in this article:
CVE-2026-63030 CVE-2026-60137 CVE-2023-50387
