CVE ID: CVE-2026-60065
Published: July 15, 2026
Description: When NGINX Plus is configured to use the Message Queuing Telemetry Transport (MQTT) filter module (ngx_stream_mqtt_filter_module), unauthenticated attackers can send requests with conditions beyond the attacker's control to cause a heap buffer over-read in the NGINX worker process, leading to a restart. Impact: This vulnerability may allow remote unauthenticated attackers to have limited control to restart the NGINX worker process. There is no control plane exposure; this is a data plane issue only. Note: Software versions which have reached End of Technical Support (EoTS) are not evaluated.
Severity: 6.3 | MEDIUM
https://cvefeed.io/vuln/detail/CVE-2026-60065
CVE-2026-60065 - NGINX Plus ngx_stream_mqtt_filter_module vulnerability
