CVE ID: CVE-2026-42533
Published: July 15, 2026
Description: A vulnerability exists in NGINX Plus and NGINX Open Source when a map directive uses regex matching and a string expression references the map's regex capture variables before referencing the map output variable. Alternatively, the same result could be achieved by using a non-cacheable variable in a string expression under certain conditions. An unauthenticated attacker along with conditions beyond their control can exploit this vulnerability by sending crafted HTTP requests. This may cause a heap buffer overflow in the NGINX worker process leading to a restart. Additionally, attackers can execute code on systems with Address Space Layout Randomization (ASLR) disabled or when the attacker can bypass ASLR. Impact: This vulnerability may allow remote attackers to cause a denial-of-service (DoS) on the NGINX system or to possibly trigger a code execution. There is no control plane exposure; this is a data plane issue only. Note: Software versions which have reached End of Technical Support (EoTS) are not evaluated.
Severity: 9.2 | CRITICAL
https://cvefeed.io/vuln/detail/CVE-2026-42533
CVE-2026-42533 - NGINX Map directive and Regex matching vulnerability
