CVE-2026-43921 - FOSSBilling vulnerable to arbitrary PHP code injection via unescaped config serialization
CVE ID: CVE-2026-43921
Published: July 6, 2026
Description: FOSSBilling is a free, open-source billing and client management system. Versions 0.6.10 through 0.7.2 have a PHP code injection vulnerability in FOSSBilling's `Config::prettyPrintArrayToPHP()` method. When configuration values are updated, string values are written into `config.php` without escaping single quotes. Because `config.php` is loaded via a bare `include` on every HTTP request, an attacker with admin privileges can inject arbitrary PHP code that executes on every subsequent request. Version 0.8.0 contains a patch. Some workarounds are available. Restrict admin access to trusted personnel only; audit `config.php` for unexpected PHP code; and/ or at the reverse proxy/WAF level, restrict access to admin API endpoints that modify configuration.
Severity: 8.9 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-43921
