CVE-2026-48614 - Plesk XML API Improper Authorization Privilege Escalation
CVE ID: CVE-2026-48614
Published: July 6, 2026
Description: An improper authorization vulnerability in the Plesk XML API allows an authenticated user to inject arbitrary configuration directives, resulting in arbitrary file write as root and full privilege escalation on the underlying server.
Severity: 9.9 | CRITICAL
https://cvefeed.io/vuln/detail/CVE-2026-48614
