CVE ID: CVE-2026-48935
Published: June 26, 2026
Description: A flaw in Node.js Permission API can cause a file metadata to be modified even on a path that was set as read-only with e.g. `--allow-fs-read`. This vulnerability affects all supported release lines: **Node.js 22**, **Node.js 24**, and **Node.js 26**.
Severity: 0.0 | NA
https://cvefeed.io/vuln/detail/CVE-2026-48935
CVE-2026-48935 - Node.js Permission API File Metadata Modification Vulnerability
