Code: Select all
sh / scripts / cwp_security_audit------------------------------------------------------
[INFO] Auditing cwpsrv (PID: )
[OK] cwpsrv looks clean.
[INFO] Auditing php-fpm-cwp (PID: )
[SECURITY ALERT] Unauthorized port: php-fpm
Error:Can't add notification!------------------------------------------------------
[INFO] Auditing apache (PID: )
[OK] apache looks clean.
[DONE] Security audit finished.
It is currently not clear what is triggering this warning.
Even servers that are not using PHP-FPM are showing this security warning box.
You can check if you are running PHP-FRPM by running:
Code: Select all
systemctl status php-fpmThen PHP-FPM isn't running.
Things you can do to make sure a hacker can't get in is:
Block ports 9000-9005
Limit access to port 2083
As more information becomes available, it will be posted here.
