PHP Warns of Critical Security Flaws Affecting All Supported Versions, Fixes Coming November 19
General Security Talk, Announcements and News
The maintainers of the PHP programming language on Wednesday issued an advisory announcing an upcoming security release that addresses critical flaws.
The release is scheduled for November 19, 2026, between 2 and 2:30 p.m. UTC.
"These releases are part of PHP's regular four-week release cycle and will address security vulnerabilities affecting all supported PHP versions," the maintainers said. "The highest severity is CRITICAL."
However, the project also noted that issues rated critical require either non-default configuration or uncommon setups. It did not disclose any additional specifics.
The update is expected to include CVE-2026-115560, a remote code execution flaw that succeeds only if the following conditions are met -
An application sets session.serialize_handler to php_binary or php_serialize in its configuration, and its code switches the handler to php with ini_set() before calling session_start().
Session upload progress is enabled, which is PHP's default.
As mitigations, users were urged to set session.upload_progress.enabled=0 until the next regular bugfix release and restart the PHP worker for the setting to be applied.
Published Date: Nov 19, 2026
https://thehackernews.com/2026/11/php-w ... flaws.html
Return to “General”
