The JetBackup hotfixes are delivered automatically. You do not need to download packages or change your update channel.
- JetBackup 5 on CentOS 7: JetBackup 5.3.12.2 with bundled PHP 8.1.34.0
- JetBackup 5 on supported operating systems (ALPHA and EDGE): JetBackup 5.4.2.5 with bundled PHP 8.3.36.0
- JetBackup 5 on supported operating systems (RELEASE and RC): JetBackup 5.4.1.5 with bundled PHP 8.3.36.0
- JetBackup MC, all release tiers from ALPHA through RELEASE: version 1.1.14 with bundled PHP 8.1.34.0
Update Manually
If you prefer to apply the update immediately, run the following command as root on your server, regardless of which control panel you use:
Code: Select all
jetapps -aCode: Select all
jetapps --list-installed
