CVE ID :CVE-2026-57162
Published : Sept. 4, 2026
Description :PJSIP is a free and open source multimedia communication library written in C. Prior to commit a1b707c, a stack buffer overflow exists in the SRTP/SDES media transport when processing a=crypto attributes during SDP offer/answer (sdes_encode_sdp() in transport_srtp_sdes.c). This affects applications with SRTP enabled (use_srtp optional or mandatory, using SDES keying). During media negotiation, the crypto attributes from the remote SDP are collected into a fixed-size array without bounding their number; a remote peer that includes an excessive number of a=crypto attributes in a single media description can write past the end of that array on the stack. This is reachable from an incoming SIP INVITE during offer/answer, before application-level authentication. Impact may range from unexpected application termination to control flow hijack/memory corruption. Applications that do not enable SRTP are not affected. This issue has been patched via commit a1b707c.
https://cvefeed.io/vuln/detail/CVE-2026-57162
CVE-2026-57162 - PJSIP: Stack overflow parsing SDP a=crypto attributes
