CVE ID: CVE-2026-53646
Published: July 6, 2026
Description: FOSSBilling is a free, open-source billing and client management system. In versions 0.5.6 through 0.7.2, when a `ClientPasswordReset` record already exists for a client (from a previous unexpired reset request), subsequent calls to the `reset_password` guest API endpoint reuse the existing token instead of generating a new one. The 15-minute validity window is anchored to the first request's `created_at` timestamp, not the time of the most recent email. An attacker who obtained the original reset link remains able to use it even after the victim requests a new reset, because the original token is never invalidated or rotated. Version 0.8.0 patches the issue. Some workarounds are available. Configure a reverse proxy (e.g., Nginx, Apache, Cloudflare) to apply per-IP rate limiting to the `/client/reset-password` endpoint to minimize the window of opportunity, and/or manually clear expired `client_password_reset` records from the database after a client reports a suspected compromise.
Severity: 7.7 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-53646
CVE-2026-53646 - FOSSBilling: Client password reset token reuse allows persistent account takeover
