CVE-2026-52747 - ModSecurity: Multipart form-data parser silently strips embedded line breaks from form-field values, en
CVE ID: CVE-2026-52747
Published: July 10, 2026
Description: ModSecurity is an open source, cross platform web application firewall (WAF) engine for Apache, IIS and Nginx. Prior to 3.0.16, the multipart/form-data request body parser in libmodsecurity silently removes embedded line breaks from non-file form-field values before exporting them to ARGS and ARGS_POST because src/request_body_processor/multipart.cc overwrites reserved bytes in m_reserve instead of appending the current buffer. This creates a parser differential between ModSecurity and backend applications that preserve line breaks in form fields, allowing rules that inspect ARGS or ARGS_POST to miss payloads whose dangerous syntax depends on a line break. This issue is fixed in version 3.0.16.
Severity: 8.6 | HIGH
https://cvefeed.io/vuln/detail/CVE-2026-52747
